I am wanting to install electric fans (looking at dual 12 inch Spals) on my 72 Chevelle. I am assuming the car currently has either a 42 or 63 amp alternator, so I am pretty sure I need to replace it for a 100 or 140 amp alternator. Is changing an alternator as easy as removing one and installing the other or do I need to do more? (e.g. replace wires with large gauge ones.)
One other question, has anyone purchased and installed/used one of alterstart's remanufactured 135 amp alternators? If so, any problems?
You should upgrade the charging wire from the alternator to the horn relay to an 8 gauge or just double the original wire up with another 10 gauge wire to the horn relay to handle the extra power you are going to need for the fans.
65 Danube Blue MALIBU 4 door wagon, Disc brakes, F41 suspension,
GM Performance Parts 350/330hp crate engine with serpentine belt system, electric cooling fans, Sanderson headers, 700R4, factory air with Vintage Air conversion, factory am/fm stereo, tilt wheel.
http://chevelles.com/showroom/JimN/Maliburearview0006.jpg
