Upon removing the original harnesses, Icarefully marked and prepped all the harnesses/wires/plugs, etc and it served me well during the reinstall. Of all the connections/wires, one marker was missing and I believe the following is true and the schematic seems to verify it. Just checking as this is no trivial wire:
At the harness, passenger side behind the headlight area, within the harness there is a heavy gauge red sticking out. It is the ONLY wire that is not connected at this point. Everything else found its' proper place. I assume this is the wire that I will splice into the aux wire at the battery + terminal and carries the power to the alternator. Yes, the wire that is connected to the terminal at the alternator is red and seems to be same gauge.
Correct, yes?
Correct, yes?
