I am going to upgrade the electrical system on my car to accomodate electric fans. The fans are going in because of the A/C upgrade I am now finishing up. As I read about this stuff I am getting confused can someone help me clarify terms?
Anybody here rebuilt one of the lower output stock GM external regualtor alternators to produce higher output? This is my preferred path since I HATE messing with electrical stuff but i gotta do this alt. upgrade because of the fans. Loading in a 100 AMP GM made external regulator seems like the path of least resistance (no pun intended). I am reading up on this subject and it appears that it can be done failry cheaply thereby eliminating all the issues of doing wiring mods to get to a one wire system. Anybody done the rebuild? What was involved and what did it take to do the actual conversion?
A couple of General questions:
CS is an AFTERMARKET alternator...right? Is it a one wire alternator or is it a 3 wire. If I were to go to a CS alternator what is involved...just a change of a connector at the alternator and no other wire mods????
SI is the one wire integrated GM alternator right???? If I go with one of those I eliminate my regulator and run a heavier guage wire from the alternator up to the horn relay. If I do that what happens to the old wires that went to the reguator and any other locations????
Thanks for your help.
