I have a 327 that I just completed a complete overhaul on, including putting on some Billet Specialties Tall Valve Covers. I am now having problems with my alternator hitting my valve covers. I have a chrome upper alternator bracket (shaped like an "r") and the lower bracket is welded to my headers. These are the same brackets that I used on the motor before I rebuilt it. I have widened the holes on the upper bracket enough to allow the alternator to go on, but it is not a sufficient long-term solution. What are my options? To further complicate the issue, I also put on a new street/strip harmonic balancer. Consequently, my lower pulley does not line up with my fan pulley. I have managed to get things working enough to start and initially drive the car, but I need your guys help in coming up with a long term solution.
What year and model of car?
Mike Newby
69 Chevelle 355/TH200-4R
97 Grand Prix GTP
64 Chevy C10 Pickup
79 Suzuki GS550
Do your heads have accessory holes in the front? If so, the solution would be to convert to the long water pump with all brackets to match.
I have the short water pump and I use the "F" bracket bolted to my header, but I modified it somewhat with a small piece of angle iron between the header bracket and the F bracket. The "F" is vertical rather than horizontal now. This gives me additional "swing" on the alternator and also gives me more valve cover clearance. You can see a pic of it here.
My Web Page (updated 9-17-01)
"I pledge allegiance to the Flag of The United States of America."
Chad Landry
TC Member #643
ACES Member #04556
'68 El Camino
If youe heads have the accessory bolt holes, the later model brackets work a lot better. You may have to move the alternator from the driver's side to the passenger side, though.
Mike Newby
97 Grand Prix GTP
64 Chevy C10 Pickup
79 Suzuki GS550
I don't have bolt holes in my heads. However, with the pictures provided I may be able to work something out. Thanks for the recommendations. If anyone has other suggestions bring'em on.
