My 70 Chevelle has picked up a few minor problems since I have had the front end off.
The Alt is not charging. 12.1 at the bat. at idle, and 11.5 v when I turn the headlights on. I had it tested last year, when I though I corrected this problem with new regulator.
Recently I was asked what year alt. do I have, and maybe I should have a matching external regulator.
Ok, I plan to run the alt back by the "Zone" to get it tested/replaced. The Alt is externally regulated and not a 1 wire alt. but don't know much more than that.
Are the external regulators all the same for these externally regulated systems?
If I have to replace it, and I go with a newer style, what year do I ask for? Assuming I get an internal regulated model and ditch the external regulator?
