G
Im finishing up my autoloc alarm install, I havent even begun to start my solinoids! QUESTION. Right now my power for the alarm is hooked into the fuse box always hot, easy... not problem. Would it be safer to wire it straight to the battery? It would be harder to get to my battery than my fuse box which is where it goes now. Thinking it might be better security to run it straight to the battery/ trunk.
G
Discussion Starter · #2 ·
If anyone has put an alarm in I was wondering where you put the main alarm box, this came with one main sensor, wondering where I should mount it.
If the shock sensor is part of main control module the best place to mount it is the steering column. If the shock sensor is separate, the column is still a great spot. If you have no room there, centered up high on the fire fall is the next best spot. Never mount the main module on the outside of the car. Near the fuse box and steering column is where all the wires are that you will need to tap into. Run your “solenoid” wires {I’m assuming these are for the doors} to that general location and wire the whole thing at once. This will help you avoid making unnecessary splice after splice each time you add a new alarm component. All of your power needs should come from the column; they are all there- constent, switched, crank, horn & ground. Your light flash wire can be accessed from the back of the headlight switch.
