would you consider a strip dominator a 'big single plane'? I thought it wasn' that big compared to other single planes but maybe i'm wrong. I have plenty of hood clearance it is a cowl induction 2" hood 69 camaro. small block sits nice and low. I think the strip dominator actually would sit lower than my current rpm air gap + 1" hvh spacer on it.hi
Ede rpm will cost upper end power not huge amounts but still . The hp cure will drop early .
A big single plain will give less response to low end throttle .
If u go the strip dominator less throttle response but negative impact might be limited due to the efi.
The gain hp from strip dominator will only be 10-15 hp why not enough cam /compression
eg a 400 from 210 heads vic jnr to strip dom ,, from 250-to 260 S/Roller gained 30hp 575hp
Torque below peak will be less
Do u want /need to cut a hole in the hood ???
Weiand 7530 s/plain 1206 ports carb mount is lower than the Ede air gap
Ede rpm 1205 ports ,
Vic Jnr s/plain 1205 ports and carb mount , higher than ede rpm
???? diff ratio means nothing without tire diameter ???
