Hello,
I posted this on camaros.net but they aimed me here as more of a performance crowd. So here goes. Would you run a strip dominator or rpm air gap on this? Combo is primarily street driven, but out of my analysis it rarely is above 3k rpm on the street so i don't really care for the argument how the bottom end will feel since i rarely ever feel it anyway. the converter is a 3k converter and 3.90 gears so it usually is cruising below that rpm range until i get on the hwy. my question is really will a strip dominator's upper end advantage outweigh the lower rpm advantages from the air gap? This will probably only come up when I'm drag racing it as that's when I'll have the traction from a dead stop launch to really feel the impact of my decisions. So what would you do? Combo is below:
bc 400, std bore and stroke,5.7" rods. compression 11:1 or so. flat top pistons with valve reliefs. quench area on deck .005
Hyd roller cam 236/242 111 lsa 108 intake centerline. .584/.584 lift with 1.6 rockers.
afr 210 heads 65cc chambers
sniper efi, so up to 850 cfm i think.
1 3/4 headers with 3" extensions for about 6-8" then 2.5" exhaust thru mufflers.
3k stall, 3.90 gears
Thanks for your opinions.
