I posted my LM-1 air fuel/rpm results on another forum and got a very interesting feedback.
Based on top end mph my optimum jetting is 76/82. Either way the mph will go down slightly. But at this jetting my air fuel ratio is only around 11.75 and the line is quite "ragged".
The response suggested that my dynamic compression was too low and that I was not getting very complete combustion. They also said that in order to use the 12.5 air fuel as a target, there needs to be more complete combustion.
Their observation was pretty good because I did not post the engine particulars until after their response.
Bottom line is that there is a lot to learn and a lot to know about using air fuel and building engines with less than ideal dynamic compression ratio.
In my case I did it to run pump gas, which is fine, so long as you understand the limitations and some of the tuning considerations. Also explains why a light car with a big engine does not go as quick as you would expect.
