I hope I'm asking this question in the right place.
Carpets in my 67 have a moldy smell. So I pulled them. Now I have a ton of old glue and a very thin rubber/latex coating between the glue and the primer. Getting the glue up is working with a heat gun (butane torch would not work), some WD-40 and a wire wheel on the end of my drill. This rubber/latex coating is another story. When I first pulled the rugs there were sections you could pull up from the floor in small pieces (like peeling paint). But the stuff that bonded is presenting itself to be a challenge. Seems I need to take the primer as well to get it all cleaned up. Which requires more work both on stripping it and prepping the metal for a new coat of primer once everything is stripped out.
My question is, rather than investing over $300 for a tool which will only be used once (maybe twice) to strip everything out, what have other owners done to remove glue and this rubber/latex coating (would love to know the name of it... some have said lizard skin... I'm not so sure...) to get it down to primer or bare metal? Or am I facing a lot of manual labor with the WD-40 and wire wheel? Its a slow process. Looking for a quicker process! Without replacing the floors. Actually my floors are not in bad shape. Some surface rust and a couple of dime or quarter slots which can be filled.
I have five hours into this with the scraping and I've only done the passenger side front seat floor area. If you throw in the tunnel work I'm looking at about 30 hours of labor and the costs of a replacement wire wheels. Not much fun in hot weather.
Any and all responses welcome!
