I am running 12.0 at 110 and want to run a 10.90. I have a BBC option or upgrade current SBC.
Vehicle:
- 1953 Ford Truck (pretend it's a Chevy if it bothers you)
- 3500 lb race weight
- TH350 3000 10" Hughes
- 4.56 spool 9" Cal-Trac bars
- Current 377 best 1.63 / 7.57 89 / 12.00 110
SBC option:
- swap from home bowl ported Vortec heads to AFR 195 or 210.
- reuse current SFT 256/264, .545/.563, 105 LSA
- reuse induction - Wieand TR with 2-600 Holleys
- Replace worn Roller rockers with new
BBC option:
- I have a primo stock 454 with 781 ovals.
- Add hyper pistons for 10-10.5:1
- Add Comp SFT 260/266 .629/.605 108LSA
- Add 2.19/1.88 valves and do my own bowl porting.
- Add RPM air gap and 850 dp Holley
- These are the major items. I have left off the small stuff so as not to bore you.
I'm a budget builder and estimate the sbc option at $2400 and the BBC build and swap at $2100.
I want to break into the high tens (knock a good second off my current ET).
This package does not have to last 10 years, 3 would be nice. It will not be daily driven. It does have to drive 60 miles to the track. I only race a few times a year (wish I could every week). I want pump gas. I also plan on a converter upgrade after I decide on the engine.
Let me know which way you think would have a better chance at a 10 second pass.
Tom
Vehicle:
SBC option:
BBC option:
Tom
