1 - 2 of 2 Posts
I have a adjustable proportioning valve that I will be installing. I had it hooked up before, but I am in the process of making all new lines so I am moving it closer to the MC.
How do I get from the 1/4" rear line to 1/8" NPT? Before I used a 1/4" to 3/16" adapter then a short piece of 3/16" tube, then 3/16" to 1/8" NPT. I would like to avoid this if possible.
I have a Jegs kit and these are the fittings it came with. Can any of these be converted to 1/8" NPT?
1/4'' (9/16'' -18) Steel Nuts
14'' (1/2'' -20) Steel Nuts
1/4'' (7/16'' -24) Steel Nuts
I ended up going with a flare and ferrule setup piecing together a few fittings I found at my local Ace hardware. It took some searching to find the right combination but it has worked flawlessly since. Unfortunately I do not remember the exact fittings I used.
1 - 2 of 2 Posts
