1 - 8 of 8 Posts
I had my rear differential rebuilt by a friend, but he didn't put in the differential fluid. I went to fill it up and I popped the cap off the breather. Does that whole plastic piece pop out? Does it twist out? I don't want to break it off so I figured I'd go against my usual judgement and ask first! Also, how do you know its full? Do you just fill it until the cap overflows?
Auto...carefully "pop" the breather cap back on. Look on the passenger (right) side of the pumpkin. There should be a plug with a square head sticking out the side. Unscrew that plug and fill the diff. with gear oil until it starts drooling out. Re-install the plug. If this is a posi. make sure to use a GL-5 type of gear oil as well as a friction modifier. I hope your "friend" gave you break in instructions. Drive around town "normally" for about ten miles and then park the car for at least a 1/2 hour before driving it again. Re-check your oil level. Good luck.:thumbsup:
Thanks guys. Good thing I asked. I didn't even notice that plug. I had an Eaton Posi installed and the tech at Summit recommended I buy 3 quarts of Lakewood BFL 80W90. At $12 a quart I hope thats good stuff. He didn't mention anything about a friction modifier. Is that something I can pick up at any car parts store?
Twelve dollars a quart for GEAR LUBE? Don't waste your money, any 90 weight gear lube will work fine as long as you put a tube of limited slip additive in with it. I run an Eaton posi as well and it's been trouble free on no name gear lube @ $5 a gallon.
Tom
1 tube of whale sperm (LSD additive) 4.95, 2 quarts of 85/90 gear lube 2.00 bucks a quart at your local autozone. DO NOT USE SYNTHETIC OIL with a clutch type posi. Screw the tech (salesman) at summit. They are inherently clueless. They didn't use 12 dollar a quart gear lube 40 years ago, and yet they
still function quite well after all that time with cheap gear oil.
You are right about syn. lube. The tech. at Eaton told me to use a good grade 80 90 and a bottle of Posi add. Take the car out ,drive it, make about 10 figure 8s in a parking lot, and you should be good for 40 to 45 years. NO syn. lube!
1 - 8 of 8 Posts
