In my 65 which I am converting to use a T56 6 speed I have to adapt my crossmember. I used to have a TH350. To adapt it will require me to use a metal extension so I can match it to the tranny. Is there another crossmember that might work better? TH400 or something?
Can I make a crossmember? What would you use to make a crossmember? I am thinking using heavy gauge steel tubing. What size tubing would I have to use?
Thanks for your help.
