Dino
If you just want to remove the plastic pedal from the rod, the pin slides right out. The only thing holding it in is the pedal spring. Unhook the spring where is catches the rod and let it unwind (a 1/2 turn), that'll free up the pin on the pedal so you can pull it out.
