1964 El Camino
What would you use to convert an accelerator rod to a cable in a 1964 chevelle/el Camino. I’m thinking of using the stock pedal assembly then attaching a cable I got from a salvage yard to the part just outside the firewall.
pictures coming soon.
I went with a lokar setup not cheap but has worked very good. I later found Nova68-74 and Camaro 67-69 is a cheaper option that is almost bolt in.
