OK!I just finished putting the POA and expansion valve on and everything now holds a leak test. I then decided to pull the compressor off to put new O-rings on and see how much oil is in it. I went to dump it into a cup and no oil came out. Shouldnt oil pour out of the compressor? If i need to replace the oil do I just pour it in the back of the compressor and how much does it hold? Its a 72 malibu.The system has been down for years. Wasnt even sure why the air did not work in the first place, so i just replaced the main things.
