When I brought this car in the garage, only three of the body mounts were actually present and had bolts holding the body to the frame. Others were missing completely, or missing the bolt. The rear-most mount on the drivers side was tweaked up about 1/2", but it was hard to tell if it was body, frame, or both. Under the premise that a good frame is the foundation of a good build, I braced the cabin with 1x1 and pulled the body off. AS it turns out, the frame was actually pretty good, and a little persuasion on that rear corner, and the frame was level and square. I carefully installed a Hellwig FX frame kit welding it in over the course of three days. Lay a bead or two, wait, repeat. Come out at 1:00am when you cant sleep and lay a bead and wait. You get the picture. I was careful. The frame stayed straight, square, and level. Once I knew I had a good frame foundation, a sandblast and rust coating, I rolled the frame back under the car. Imagine my surprise, dismay, shock, horror, etc. when I say the 1.5" gap under the #1 Drivers side body mount. The body is sitting flush on all of the other mounts.
An aside - While the frame was out and just for giggles I laid my new floor pan down on it with the body mounts and everything was perfect, so I know this is not a frame issue. SO the question becomes what to do? This is a little beyond what I planned for, but I know anything is fixable. I'd like to hear your thoughts.
Another aside - I have just about every piece of new sheet metal for this car - Trunk pan, floor pan with inners, firewall, complete lower cowl, and cowl end caps and hinge panels, quarter panels, and rear tailight section. I'm not sure how this problem will be resolved just yet, but I can tell you that the new floor pan sitting flat on the shiny clean frame is giving me some radical ideas. Thanks for reading, and as always your responses are welcome.and appreciated.
