What about a 4 door? 68-72.
1966 (and probably 1967):Now if someone else can fill in the 64-67 frame info it would be greatly appreciated. :beers:
Typically, these should not be boxed. the Chevelle wagon was not boxed, as the roof will help keep the body from folding...Would the frame on a 67 olds cutlass station wagon be the same as the 67 elcamino & chevelle wagon? Would it be boxed?
Thanks, that clears things up - my post above could possibly have led someone astray......the Chevelle wagon was not boxed...
The crossmember for 64 and 65 El/Camino and Convertible are the same.Vern,
Do you have any info on early Chevelle/El Camino? I need to know difference between the transmission crossmember of '64 El Camino/Chevelle convertible (boxed frame) versus the hardtop (open frame).
thanks,
trannyman
