Does anyone know what size flare nut or tube nut i need to screw into the 98 -02 fbody rear brake hoses. I want to be able to use off the shelf hoses and not have to special order customs
I'm putting one of these on my 69 chevelle, I modified the original camaro brackets, used the camaro hoses, and used an inline tubes oe steel rear axle set, that allowed them to screw into the chevelle block on the center of the axle, and then cut and flared the outer ends to the bubble flare style fittings on the outboard ends.Does anyone know what size flare nut or tube nut i need to screw into the 98 -02 fbody rear brake hoses. I want to be able to use off the shelf hoses and not have to special order customs
