1 - 2 of 2 Posts
I just bought a complete rear disc setup off a 91 formula with a 10 bolt. Does anyone have any advice or suggestions as to what problems I should expect with this swap?
Any advice appreciated. Thanks, Kevin
Od of the axle flange must be under 5.95" ( i think) and you might have to re-drill the pattern on the bracket. Other than that, make some brake hose bracket and it's a go! or a woah! depending how you look at it.
1 - 2 of 2 Posts
