Purchased a new Edelbrock mechanical fuel pump and I had to go to a 90 degree hose to NPT inlet fitting. So I use a liberal amount of ARP fitting sealant that I had left over from when I did my cylinder heads on the NPT threads. I tightened the fitting and its snug. I could maybe go another 1/4 turn, but then the fitting would not be lined up with the fuel hardline. I let the sealant cure over night although I'm not sure it actually cures. This is the type of stuff that stays soft.
Fired the car up. Seemed OK. Took it for a 10 minute ride and it leaked. I could see where the fuel had blown out all the sealant on about half the fitting and was bubbling out.,
SO much for the wriitng on the sealant tube that says can handle 10000psi of pressure!
Thoughts as to where I went wrong?
