1 - 8 of 8 Posts
Hi guys I just bought a 1983 El Camino. I don't under stand is all the GM cars from that time leak on the passenger side. I mean that I had a 1984 Regal it did the same thing, my sister in law had a 1980 Malibu same thing is there any thing I can do, I don't know if it is the windshield,or the fire wall, or some thing else any body know please help thank you Jim Clark
Discussion Starter · #2 ·
my other car is a 1966 Chevelle corvette torch red with a 396 M21 and a 373 rear the EL Camino is my second car it is my new project I thought you guys might have some Ideas what to do with the leak thanks
To help narrow down exactly where the leak is, get in the car and have someone run a hose over the area, starting at the bottom and working their way up the car with the hose until you can figure out where the water is coming in.
Same here, 84 Monte, leaks into foot well from the area of/under the AC box. Not coolant, have tried the hose, can't find the leak. However, with a long enough rain storm, theres the water. May need to check with the dash out...
All ears on this one as well.
Tom
The gasket between the heater box and the right kick panel (metal opening under plastic kick panel) shrinks and water leaks in around it. Pull the heater box off and change this rubber seal and I bet you'll be leak-free.
· Super Moderator
I just sealed up the outer heater box on my 84 S-10 for the same exact reason :( I just used "Right STuff" RTV Dry as a bone after 2 inches of rain last week :)
Another thing to check is if there are any wires going through the firewall that side. I had a leak in a truck where the water would run along a pinch weld, drip onto the wires and actually trickle back into the cab. Smeared a buch of goop on the wires and it's been dry since. It only happened when parked nose down in the driveway.
1 - 8 of 8 Posts
