Okay, my boss just gave me an 454 4 bolt main block that has been bored and has new cam bearings aswell as new freeze plugs installed.But this engine has been sitting in storage for 5 or 6 years since all of that had been done. He gave me a set of heads aswell that havent been touched yet and im not sure if they came of this block or not. My boss doesnt know much about the history of this 454 block or the heads, someone gave it to him years ago in the condition they are now. The #s on the block indicate it is from 1978.Its a 4 bolt main so i assume it came from a truck or maybe a Suburban, dont know. The heads are a set of oval ports # 3993820. I would like to know if there a decent head for a street machine. Id like to build this 454 for my 70 Chevelle someday and would consider using them.They have 113.06 combustion chambers with 2.06/1.72 valves. Ive read a little about them in my Chevrolet By The Numbers book, and it says that these heads are a oval port design that are identical to the #3931063 except these 820 heads are a open-chamber design and the intake and exhaust seats are redesigned and the spark plug seat is now tapered. Just wanted to know if any of you big block guys know anything about these heads and if they may be worth using for a mild street setup.Maybe install bigger valves with a little head work,mild cam, good intake,good ignition and ofcourse a set of headers. Or should i look for a set of 049s or 781s?...
