I hooked up my neutral starter switch tonight on the Mega Shifter,now its time to hook up the back up lights,,,can anyone tell me what color the wire is that goes to the back up lights and tell me where to locate this wire under the dash?? as always,thanks in advance...Bob
Bob West
1972 Malibu
454+
TH350-3.73's
3900 lbs.
1.79 60 ft.
12.06 @ 112.89
Bob
It's a light green wire. On the automatic shift cars it comes from the neutral safety switch. The N/S has 6 wires. The 2 in the center are the back-up switch. Other part of the switch has a pink wire on it.
The light green runs all the way to the trunk. Should see it on the harness connector inside the trunk, left hand side.
Thanks again John,I was looking in the wrong place for the back up lights wire,I was looking at a black connector that is hooked to the steering column,when it was a white connector closer to the fuse box,now I have a neutral safety switch and back up lights...
