1 - 11 of 11 Posts
I understand some of the pins have to be moved around. Is there a simple answer as to what doesnt work if you don't move the pins? car has idiot lights the cluster is idiot lights, dash has no seatbelt light. car isnt a resto or anything, I just want the idiot lights to work and gauge lights to light. Heater blower,wiper would be nice too. Thanks Jim
Simple answer- Nothing will work. The main power feed on a 71 is in the forward lamp harness, the main power feed on a 72 is in the engine harness. If that wire is not moved nothing will work. Other items that won't work-windshield wipers, temp light, probably others that I don't recall off the top of my head.
Thanks elree, I actually did a search and found a earlier post that you did, it explained where to move each wire in the connector. I should have searched before asking. Now I just have to figure out if it actually is a 72 harness. the dash doesnt have the seat belt light. I also have the forward harness out of a 72 chevelle, I dont know if it would be easier to just swap out the front harness or swap out the pins in the bulk head. Is there any tags or easy tell tell signs to see if the harness is out of a 72 or 71? thanks Jim
Thanks! I'll check it out in the morning. Jim
Not all 72's have seat belt light and buzzer but all 72's have TCS delay relay and key minder buzzer in harness that 70/71's don't. But as Elree said the easiest way to tell is the wiper switch.
Jim: I have a '71 harness that is pretty good EXCEPT that some wiseguy cut off the dimmer switch connector. Do you want to swap it ? I bought a '71 dash panel thinking that it was the same as '72 and found out later that it is not.
Hi Jeff, its definetly a 72 harness, if you want to swap im game. this one doesnt look cutup all the connectors are there. Jim 885 7017
Administrator
Hey Jeff the panel you got from me is a 72 if that is the one you are referring to. There should be a seat belt warning light in the cluster.
thanks for the heads up. Jeff just told me his is a sweep harness, unfortunatly I need a SS harness. Jim
1 - 11 of 11 Posts
