you are going to love that.
Great article, I live in Happy Jack AZ, and I'm starting to restore my 72 Chevelle Concors Wagon. I see you didn't use tubular A arms. Is there really any benefit to them. Just looking for a nice smooth ride.Thought I would post a quick update to let you know it has been started. After the VATS was disabled it fired right up. Still have a lot of work to get it back on the road but I'm happy. Wednesday it gets exhaust done after that I'll be able to run it more without irritating the neighbors. The belt alignment was terrible finally have everything running true by placing different thickness spacers on the idler, alternator and AC mountings.
One thing I did not expect to have trouble with was the transmission. For reasons not yet clear to me the electrical connector leaks with the harness plug installed. Remove the connector the leak stops. Plug the old connector in and no leakNot sure what to do but only have tomorrow to resolve it before exhaust pipes are in the way. I'm going to call the company that built the harness to see if they have any suggestions. Anybody here have any?
LQ4 first start open manifolds, no O2's, no MAF but it's running![]()
I’m in Surprise (west Phoenix). Most Tubular a-arms will come with poly bushings. Those will ride a little harsher than rubber, but have less deflection when cornering. If you are going for smooth ride, I’d reuse stock arms with new rubber bushings. The stock suspension is pretty compliant, and should ride pretty plush. That being said, the stock suspension is NOT a performance suspension, so if you are looking for cornering abilities. Then I’d suggest some changes to the stock suspension.Great article, I live in Happy Jack AZ, and I'm starting to restore my 72 Chevelle Concors Wagon. I see you didn't use tubular A arms. Is there really any benefit to them. Just looking for a nice smooth ride.
Thanks,
Thanks for your reply, going to stay with the rubber.you are going to love that.![]()
Thank You, I'm going to stay with the rubber.I have rubber in my wagon front and rear. Rides great. Also added bigger sway bars, 1.25" front and 1" rear. Improved handling dramatically and still has a smooth ride.
Gene your probably correct. It was a low compression fuel injected engine from a 99 motor home.
Philip, where did you get the carpet for your wagon?Gene your probably correct. It was a low compression fuel injected engine from a 99 motor home.
Ha, either way, 20+ mpg , or smiles per gallon, still beats 12 man! DRIVE ON! My contention is that only BBCs with compression and a mild build can squeeze decent mpg, not 8:1s. All that computer tuning business scares me tho.Gene your probably correct. It was a low compression fuel injected engine from a 99 motor home.
Is Hinshaws a car dealership? Can't seem to find them as a parts shop.My carpet was purchased from Hinshaws. I don't remember the brand.
