The rear brake hoses and front calipers arrived today, still waiting on the rear springs.
I'm using the stock F body hoses at the rear calipers and the stock A body hose from the frame to the rear. The tabs to secure the hoses on the axle tube were cut off of the brackets that came from the brake donor car. There is a right and left bracket mounting to align the index points, the hoses are the same but mount opposite each other.
The stock 12 bolt lines were shortened and a flare nut from the donor car installed on the line before creating a bubble flare on the end to tie into the F body hose.
Whoever coined the phrase "change is good" must not have built hot rods. Seems the simplest things often get complicated. I replaced the sheet metal cover with an aluminum cover with bolts that add support to the bearing caps. Seemed simple enough until the brake hose install...and the line wouldn't reach the frame. An adjustment had to be made to the bracket to locate the hose back in the stock position. A a piece of scrap metal left over from cutting out the parking brake cable brackets was used.
