I have a 1972 chevelle malibu.
It has a headunit but the wires arent hooked up, i plan on getting new speakers and maybe aftermarket headunit. I dont know where the speakers were originally
it has a new packkage shelf so if they were there theyre not now, but i did look in the truck under the package shelf and i didnt see holes to fit 6x9s.
Could you tell me where the speakers are located in a 1972 chevelle malibu?
Most package tray material does not have the cutouts for speakers except for the mesh style. So you may be trimming the material and mounting speaker grills. As far as the metal looking from inside the trunk there should be cutouts for 6x9's. The dash will have either the mono in the center or two on each side and thats it. I am going to be adding some on the lower kickpanels and they sell those already in the plastic from NPD or Yearone.
Jim is right- there's cutouts in the metal where the back package tray goes, and depending on which dashpad you have, you'll have the mono center speaker or 2 on the ends of the dashpad for stereo applications.
I bought a stereo dashpad at a flea market and used Infinity 6 x 9's in the back and 4" in the front. I'd suggest either doing what Jim did to the kickpanels, or go with 3" round in the front. The 4's are tough to fit in the dash area.
I think there's cutouts in all Chevelles deck panels for speakers. You nearly have to crawl into the trunk to see them. I did, and used the metal openings as a guide to carefully cut thru the package tray material for my 6 x 9's with a stanley knife.
