I swapped out the gear box now seems like it fits tight so tight that wheels can't be turned, am I missing something?
Power steering pitman arm for a 1968-1972 Chevelle if you say the car was previously a P/S car and didn't replace the pitman arm you should have the correct one.Previously i had power steering, what pitman arm works for the GC gear box swap the chevelle PS pit man arm or thr manual?
I have a 70 and appear to be at 5 inches to 5 1/8 inch on both the pitman arm and idler. The bar appears straight between the tie rod connectors. Yours appears to have a slight bow in some of the pictures. I have enough room to get my finger between the bar and frame. I have a deep Milodon 7 qt oil pan and about 3/8 inch clearance between top of bar and pan.Pitman arm measures about 5 1/2 from hole to hole
