I recently got a refurbished Delco AM/FM stereo to put into my 72. ( I believe it's actually a newer radio, maybe 73-74? Dimensionally the same as the 72.) Anyway, the car was originally am equipped. I need speakers for this radio and have heard I need 10ohm speakers and cannot use newer speakers as they are 4 ohm and I'll blow the output in the radio if I use 4 ohm speakers. I have a few quesions:
Can I somehow put a resistor in a newer speaker to give 10 ohm resistance?
If not where can I get 10 ohm speakers?
Lastly I was really hoping to add an Amp to this radio using a line output to RCA adapter and wiring it into the amp that way. Can I do this or does that go back to the whoe 10ohm VS 4ohm problem?
Is there any way to make the amp work with the old radio?
Thanks!
Thanks!
