Can I put boxed control arms and sway bar on a 4 door? ground up has this
1964-1972 CHEVELLE & EL CAMINO REAR SWAY BAR & BOXED CONTROL ARM KIT
those work on a 72 4 door? What springs should I use with it? Small block.
The rear end is being switched out and I want this done at the same time. Thanks
YES! I just did this last Thursday to mine. Replacement Moog coupe springs work fine.
I answered your PM too... :thumbsup:
· Vendor
Hello,
Yes the four door is the same as the two door.
Please keep us in mind for the control arms and sway bar.. we have rear sway bars for $149.99 each and lower control arms starting as low as $129.99 a set. Both items are available in Red or Black powder coat as well.
www.umiperformance.com/4015
www.umiperformance.com/4034
If you have any questions please ask and I am glad to help. Thank you!
Ryan
