I am attempting to put a 70 SS dash with gauges into a 71 Malibu sweep gauge. I have the wiring harness for the SS dash Every thing works except for the tach, and i can not get the Alt,fuel and temp gauge to power up when key is on. All sending units check ok.Also high beam indicator light will not go out when key is on ,high beams work.How do you hook up tach to work. Thanks
