Yes they will. You should get everything off the donor car and I mean everything. It will still be cheap. If you have drums on your car, you will have to change the hard line that goes behind the engine crossmember (it is a smaller diameter), you will have to change the the lines from the frame rails to the caliper also. I put the brakes from a junked 72 Vista Cruiser on my 67 El Camino. Any A Body with disks will work. They are all the same. Stay away from the multi piston caliper however. They had some problems. Also get the later one piece rotors. Any questions, email me at
[email protected]
