My quarter window keeps falling out of track and after looking it appears the plastic roller is missing.
I really need to fix this tonight if possible so I can race tomorrow night. Trying to locate the part I should be looking for to see if the restoration shop or the HELP! sections might have something.
I am coming across several different types from push ons to screw on studs with the plastic attached....any way to tell what I need before the car is apart?
Discussion Starter · #2 ·
Well got in there and looks like it requires the stud type with the plastic roller. Is there an easy way to get the old one out before I weld the new one in?
Looks like I might be able to grind it off and tap it out, or do they have to be drilled out?
It’s best to remove the window completely. Funny thing is I still have this setting on my desk from when I did mine. I always order extra when I’m not sure what I’m doing. It actually goes through the glass…
You remove it by the 2 holes and spinning the entire end off.
