I've got an easy one, but to double check.
I've got a 71 guage harness with a 3-wire connector for the wiper switch mounted in a 72 guage dash with a 4-prong switch. looking at 72 schematic, the fourth prong is a ground. can i use the existing switch? I've searched previous posts but couldn't find the answer.
Rodney M
72 convert
connector fits,
but not sure if wires correspond to correct lug on switch. anybody got the correct color code for a 71 wire harness wiper and for a 72 wiper switch?
Rodney
This pic shows the correct orentation of the 72 switch connector on a 69-71 switch. The lower black wire is the switch ground, the other three are the same for all years. The switch needs to be grounded, a wire from the metal cluster back to one the switch mounting screws or clip the lower black wire from the connector, crimp on a ring lug and attach under a mounting screw.
