I have a '71 chevelle in #2 condition. It has ps,pdb,ac,12 bolt rear-posi, and dual exhaust. The numbers match. Can someone tell me what I have? The vin# is 136371B117990. The engine code is 11B117990 10908ccc. This car has a 4bl carb.
136371B117990
1 = Chevrolet Div of GM
3637 = Malibu, 2dr, coupe, V-8
1 = 1971
B = Baltimore Maryland assembly plant
117990 = Fisher Body sequence #
Engine 11B117990
1 = Chev Div of GM
1 = 1971
B = Baltimore
117990 = last six digits of VIN of car engine originally installed in
10908ccc
1 = Probably is a T which is Tonawanda engine plant
0908 = engine build date = Sept 8th
ccc = ??? I show no chevelle engines with this code.
CE = Counter exchange
CCA = 307, std trans
CGA = 350, std trans
CGB = 350, Powerglide
CGK & CJJ = 350, std trans, 4bbl, L48
CGL & CJD = 350, TH350, 4bbl, L48
Steve Strasemeier (70SS)
You can also check under full size chevy codes in Chilton's. Also in Year One catalog in the engine section they have codes. I had the same problem with my 350 in a '71 malibu. The code was CGC for 350 2 bl and it was under full size chevy and in the Year One catalog.
Yuri
