How to install outside mirrors on 71 chevelle its already a driver side there want to replace and also add passenger side mirror
Thats exactly what I did
If you look inside the drivers side you'll see some metal attached to the inside of the Left (drivers) side that isn't inside the passenger door panel.That heavier metal is designed to back up the mirror and add a little strength to where the mirror mounts.So when I added my passenger side mirrors I cut a couple of pieces of thicker sheet metal and copied what was on the drivers side.I just used some A plus B epoxy to glue the support pieces to the inside of the door,worked perfect.
