I have a 1971 Chevelle that I am restoring.
I had to purchase a new hood and hinges with new springs. The hood is the SS or Heavy Chevy type hood. I can not adjust the hinges so that the back part of the hood closes down correctly. The back part of the hood is always raise up. Even if you push down on the rear of the hood, it will not sit right. I adjusted the hinges down as far as they will go with no changes. It is like I need to files the holes longer in the hinge so I can adjust it to go lower in the rear. Any ideas. I know this is a problem with this big hood. My old hood and hinges did the same thing. I thought by buying new hinges and spring, that the problem would go away. The problem is worst with this new hood.
Keith Cooper
[email protected]
Actually it works backwards, you want to raise the rear of the hinge to get the hood lower. Give it a try.
Dave
70 chevelle ss396 conv
66 chevelle ss396 hdp/conv
72 chevelle
TC member #493
Never forget Earnhardt!
That is EXACTLY correct. The hinges adjust the opposite direction from what you would expect. As mentioned, try it!
Tom Parsons
I also think that the rear cross member type support on the rear of the underside of the hood is hitting the cowl. I think that this is a problem also. I am not sure how to fix it.
I also wish someone would go into more information about how to adjust the hinge. Do I only want to raise the rear of the hinge to get the hood to close right?? or both the front and the rear hinge at the same time. If so, what way do I adjust the front part of the hinge?
Keith
[email protected].com
It's basically a trial and error approach to get the hood properly adjusted. But, if the rear of the hood is high, the front of the hinge needs to go down (or the rear of the hinge needs to go up).
It's one of those things that is nearly impossible to explain, it needs to be demonsttrated in person.
Tom Parsons
