68-70E 350, 427 & 454 & 71 LS6 Air Cleaner Mount Base
Yup, the #163 aluminum intake is what is on my one car with the post #10 parts.A 70 SS that was originally equipped with an open element air cleaner (non cowl induction) used a low rise intake. The breather tube pointed toward the heater box and used a curved hose that connected to the 90 degree fitting installed in the valve cover. Not the one shown in post #10. The straight hose pictured there was used with the 69 and earlier tall intakes.
OR (as I've seen examples for sale at swap meets) - beat the daylights out of the tube in order to flatten it enough to clear the acc. pump. I don't believe this ever workedThe vent tube contacts the rear accelerator pump. Many people removed the vent tube and plugged the hole then installed a push in breather in the valve cover.
It doesn't fit because of interference with the secondary accelerator pump...works with vacuum secondary Holleys. I used a breather and removed and plugged the tube in the base.I use this base on a Holley 3310, I don't see why it won't work with a DP850 unless the throat is larger. I decided just to go with a breather in that vc the height difference is way off and a longer 1" hose would look stupid.
