Would you change 781's over to 702s for my combo? I got ahold of some 702s and am wondering if the increase in cr would be worth giving up some of the better flow of the 781's . I am so close to giving this heads a try .
Still learning on what works on big blocks. I was about to buy some aluminum heads off ebay but thanks to this site I avoided what would of been a costly mistake. I guess I am at a point with all my small problems that I am thinking by combo over and am wanting to do some changes(I think)The 702s have a pretty tight chamber, If your .275 dome pistons are designed for the open chamber heads you will have serious clearance problems. Why are you wanting to change? the 10.2 compression you have in your signature should be plenty for a street pump gas deal.
I'd keep the heads you have, RPM airgap, and 850dp minimum, you'll love a 950HP. My son swapped his 750dp for a ProForm 850 at the track yesterday and picked up 2 tenths and this was on my old .030 over 454 with a small Lunati solid ft cam. He had run a best of 12.oh's with the 750dp last fall, ran [email protected] yesterday in much worse air, bolted on the 850 and went [email protected], jetted up a couple sizes in back and went [email protected] 111mph. That same motor went a best of [email protected] in my car with more suspension work and a 950HP.
I am going to give the edelbrock rpm a try with and without the spacer. I have always wondered if a dual plane intake would work better with this setup. I have a feeling I will be pleasantl surprised with the results of the edel. rpm. I am also getting a bigger carb on there. What do you think of my shift point of 6700rpms ?Heck...I'm running a Performer RPM and a 2" open spacer on my 505, shifting at 6k. Before I swapped to aluminum heads, 2 different times I lost 60ft and e.t. swapping to a Vic Jr from the Perf. RPM with a slight increase in mph, and I think the Vic Jr is a much better intake the Holley Strip Dominator.
What would be a shift point to come down to ? How about 62-6300rpms. I understand I'd be guessing but its worth a shot and the e.t s wouldn't lie. I just wish my local track would supply more than e.t . The mph would info would have me completely heading in the right direction. One other thing that has got me thinking my combo over is the wifeys' comments regarding the 383 I had before my current combo(just for the record , I'll never regret going with the 496). Comments like " it just doesn't run like the old(383)motor". It sounded better. She means well but she makes the comments at the wrong time , like when I am having ignition problems in the middle of a competition! She understands a little about engines but not enough. I know my 496 has way more than my old 383. I know torque wise my 496 kicks the old 383s' azz and top end it does better to. My best with the 383 was a 12.3 at 109 mph with great traction. This 496 gave me a best so far of 12.4 mph?? with traction issues. I have given up the 702 idea , will stick with the 781s until I get some quality aluminum heads probably some Brodix RRs . I will get the edel. rpm ordered along with the bigger carb , lower shift points and see what she does.6700 shift point is way too high. 496 motor, w/ovals and 246* cam probably has peak HP around 5800-5900.
