What's the cam, heads & comp. ratio?
If I were you, I would stay completely away from that Boss Hog garbage. I had one of their converters in my 400 and it cost me a transmission. They reused a stock cast iron hub (or spline) inside and it shattered on the one-two shift (that is what Hughes told me when the cut the converter open). It took out my input shaft, which caused debris to score the forward drum, as well as damaging the planetary gears. Go with a known name brand converter.
