Has anyone run into this..
You push the button, you can see the motor turning behind evrything is working, BUT the lever/arm that engauges on the the pump doesn't move by itself..if you give it a slight push with your finger...it moves for a little bit and then stops....you can repeat it over if need be.... Anyone have a idea how to fix this?
