I am restoring a 70 ss that was stripped when i recieved it. my question is, from the rear to the front is two gas lines, one 3/8 main line and one 1/4 return line, the 3/8 line i know goes into the fuel pump, my question is what path does the return line take? Thanks Steve
The 1/4" return line runs parallel to the 3/8" feed line, and even gets held down in the same frame clips. The correct fuel meter (sending unit) has two fittings on it, one 3/8", and one 1/4". The fuel pump also has two fittings on it, same sizes. Use an AC Delco pump. They're cheap, and they fit. If I remember right, the number you need is a 40727.
boiling fuel = vaporlock
and
vaporlock = badthing
therefore
boiling fuel = badthing
[This message has been edited by michael j (edited 04-14-99).]
