BK radiator tag for L-34 396/402 350HP TH400
BR radiator tag for LS5-LS6 standard cooling auto
BQ radiator tag for LS5-LS6 standard cooling manual
BJ L-78 396 375HP AUTO RADIATOR TAG Code
I have combined a few posts for you to better aid you in this area. The stamped codes are near the top of the tank . These are stamped from the inside of the tank out so they will be raised. The tag will be attached on the same tank roughly halfway down again facing the engine. Only 2 places on the radiator will exhibit any date code. Both are located on the big tank with the radiator cap. There is a pair of production codes stamped on the tank facing the engine near the top of the radiator. 4 speeds use an XJ code and automatics carry XP . These letters are approximately 1" tall. In between these 2 large letters will be 1 smaller letter that denotes the month that the tank was stamped ( IN TH E PIC below). These tanks are dated like most Chevrolet parts A-M for Jan through Dec skipping the letter I .
The other date is located on the radiator tag beside the part # stamp. An example would be 3017248 9 which is the part # and date example for a PD 4-row HD cooling radiator with automatic trans. 3017248 is the complete assembly part # and 9 would be for 1969. If the small letter between the X and the P was an M than the radiator would be dated Dec of 1969 based on the tank and tag info.
date of B = February. This tells you that that tank was stamped in Feb. not neccessarily that the rad was actually built in Feb, but if it wasn't I'm sure it was close. XP is the code assigned to that tank for identification purposes and was used on automatic trans equipped cars.
Your tag is like the buildsheet for the radiator.
I F is the code for the driver's side tank used on 4-row HD cooling applications. It will display these letters I F on the tank about halfway down on the side facing the engine.
X P is the code stamped as you found near the top passenger side tank, again facing the engine. The smaller letter B located in the middle of the Xand the P is as you guessed, the month code of that specific tank.
The 74 has always been regarded as the core part of the radiators I.D. code.
There will be a part # stamped into the tag on the flat portion of the tag that attaches to the radiator tank. There is a space of about 1/4" then another single digit will follow. This is regarded as the year of manufacture.
Your tag should be stamped 3017248 with either an 8 , 9 , or a 0 for 70 andpossibly a 1 for 71 as this radiator was used in both Pontiacs and Chevrolet A-bodies during this time frame (you can bearly make it out on the Tag in the pic, on the flat portion YOU CAN REPLICATE THIS ON THE REPRO TAGS WITH A NUMBER STAMP).
PD is the broadcast code that GM assigned for the complete radiator as a unit.
:beers:
