Here's one for you guys. I've recently picked up a 70 velle. It has sat since 1993, but only has 43+k miles on it. The engine, trans, interior/wiring seem flawless but I do have a electrical problem I'm chasing.
The horn relay buzzes when the car is not running and you open the door. If I push the dome light switch in it stops, if I start the car it stops. It does it with the key in or out of the ignition switch. Since it had the original relay and voltage regulator, I replaced them with new ones (I kept the idle of course), and of course it has a new battery in it, but it still does it. the only other thing that seems to be wrong is that I have no high speed blower and the idle is set so low that the alternator light flickers on of unless you apply a little gas. The low speed and middle speed blower fan settings work fine!
I'm stumped, short in the dome light circuit? but the dome light works fine, all lights, accessories work, the horns work! event the dash clock and fuel gauge work perfectly!!
any ideas??
thanks in advance for your consideration
ProfSS i.e., rick
any ideas??
ProfSS i.e., rick
