this weekend, i plan to remove my idiot light cluster and install a gauge cluster. although i have the gauge harness, the fuse box is rusted and i don't want to use it. so, i am going to convert the harness connector terminals as necessary to match the gauge printed circuit. i know i've got to run seperate wires for the clock, amp meter and tach.
any suggestions as far as removing the dash? other wiring, etc?
i know how to remove the pad and heater pane, but that's about as far as i've gone.
somewhere, i think i read that i must disconnect the charge light wire or it may drain my battery?
