As promised here's the door pictures.
Thanks Mitch. Smells better too. Still have some bugs, but I'll get'em.Huh, I had looked at that conversion many years ago, but went with Pertonix. Interesting that it works on the original resistance wire and down to 6 volts momentarily.
I have, what is left of, the wire harness from my '66 that was butchered by a PO. I'll see if it still has the ignition wire, but most of it under the hood was replaced with all the same color wire.
As a bonus, the barn looks much cleaner and brighter inside from all the cleaning !!
Thanks, I'll be waiting to hear on that wire!Huh, I had looked at that conversion many years ago, but went with Pertonix. Interesting that it works on the original resistance wire and down to 6 volts momentarily.
Yeah, just need to look harderChris strong magnet to find that clip
Yes, I added the second loom. The AIM shows the passenger side for the speaker wiring. Everything else is in the drivers side.Chris did you add the other flat wire loom that geos along the floor from front to rear OR did you have two? Thinking one is for the normal wiring and the other for the power accessories windows Etc?
