Let's be careful about the booster-to-master cylinder pushrod length.
Some masters use a long pushrod, some use a short pushrod. Most pushrods aren't adjustable, and the ones that are won't adjust from "long" to "short".
There was a time I thought the short pushrod/shallow pushrod seat in the master cylinder vs. long pushrod/deep pushrod seat had to do with Delco vs. Bendix master cylinder/booster pairings. I'm not convinced any more that's exactly how it works.
All GM boosters have the same bolt pattern to the firewall as well as to the m/c. The only difference can only be the push rod length.
With Delco-Moraine boosters (by far the most popular models), you can easily swap the 2 push rod models that exist. With Bendix, you are stuck with a long push rod.
From what I know, you are right and push rod length was a Delco-Moraine (short) vs. Bendix (long) thing.
In my '69 Pontiac Service Manual (which covers all Pontiac: full-size, Grand Prix, Tempest, Firebird), the brake chapter is divided into 6 sections:
- standard brakes (manual pedal, drums, hydraulic system, parking brake)
- disc brakes (which covers only disc, caliper and metering valve)
- Delco-Moraine power brakes
- Delco-Moraine heavy-duty power brakes (tandem diaphragm)
- Bendix power brakes
- Bendix heavy-duty power brakes (tandem diaphragm)
The 4 last sections have no mention of model specifications. There is a «push rod adjustment» sub-section in all 4 sections.
Both Delco-Moraine models use the same J22647 gauge for the push rod adjustment (conclusion: all Delco-Moraine have a short push rod).
For Bendix models, they are 2 different gauges (J7723-01 & J22644), but the specs are given to build one yourself or measure it directly:
- single diaphragm: 1.225" (min. 1.210")
- tandem diaphragm: 1.200" (min. 1.185")
Which are clearly 2 versions of the «long» push rod.
What? 2 versions of the «long» push rod? Do we have 2 versions of m/c also? Apparently there was. In the «standard brakes» section - where the hydraulic system is explained - there is a «master cylinder usage chart» which is separated into 2 sections - you guessed it - Delco-Moraine and Bendix. Note how there is a m/c for «Bendix power drum» and another one for «Bendix power drum (heavy duty)»:
Note also that it seems that only the full-size Pontiac models could have the Bendix boosters.
So the long Delco-Moraine push rod came later. But I don't know if it is GM or some aftermarket company that created it. I suspect GM abandon Bendix boosters at some point but they still needed a Delco-Moraine long-push-rod booster version for replacement part.
In case - after reading the previous - someone asks the question: How do you adjust a non-adjustable Delco-Moraine push rod? If the push rod was out of specs, you had to replace it with a
«service adjustable push rod and adjusting screw in end to match height of gauge.»
Yep, there are also «short» adjustable push rods out there.
