It should be much easier to install the bumper after the brackets have been installed on the frame. Not to say that you might have to adjust the brackets to line up with the bumper bolt holes so leave the bracket bolts on the loose side so that you can move the brackets around if necessary.
Just an aside - I screwed up my back royally when I installed the front bumper on my '70 alone. Get some help if you can.
